Connection BS5E [Powerlink - RJ45 - AUX] BS9K
Hello everyone
My current AV installation includes a Beosound 9OOO connected via a Masterlink cable to a BV7-40, this one connected to b & O speakers. I want to add a Beosound 5 Encore to this setup but for aesthetic reasons I don't want to use the 3.5mm port.
My wish is to use the Powerlink port of the BS5E and connect it to the Aux port of the Besound 9000.
1/ To do this, I want to use a PowerLink - RJ45 cable, and connect the RJ45 to a classic internet switch and on the other side. from the switch connected another RJ45 - Aux cable to BS9K, is it working ?
thanks a lot for your help,πŸ™‚
I am not quite sure, that I understand your reasons for using a β€˜classic internet switch’!
Why not just run the cable directly?
And beware, you then have two volume controls, which can be fiddly.
Hi
Thanks for your reply,
I didn't find a cable to connect the BS5E Powerlink output at the Aux Input from BS9K but maybe you would know a seller? thanks!
H
Hi
H
Have a look at the nice guy at the buttom of this site.
That is Steve - a sponsor of the site - he makes all sorts of cables for B&O stuff.
Just go to his website soundsheavenly.com and drop him a message.
I asked Steve about a cable to connect the powerlink output from my BS5E to the Aux input from my BS9K, but he does not sell it. He offered me a cable to connect my BS5E from the 3,5mm output to Aux input, but i didn't like the aesthetic from this solution.
That is the reason why i asked if it is possible to connect a PowerLink -> RJ45 -> Hub/switch -> RJ45 -> Aux. These 2 cable exist.
Did you try a regular B&O 7 pin din aux cable?
Never tried what you ask for - would not have that idea….to be honest - can’t imagine that that would work.
How about this one to connect the cables you mention:
(Be sure to use good shielded cables).
Hi, Millemissen suggestion is good - you do not need a switch, only a direct electrical connection between the pins of the RJ45 plugs.
This is the pin-out:
So unless I mix in- and out up, you will get the signals from pin 2, 3 and 5 from the BS5E into the BS9000. The other pins you could even snap off on the DIN plug if needed. There will be double volume control! So I am unsure how that ends up! Good luck. Johan
Thanks for your reply.
I am on fire 😁, i bought a powerlink cable (MKIII 4 cores) and Din 7 and Din 8 male connector.
I hope everything is ok.
Just be aware, you cannot run this through a switch (which is an electronic devivc), just through/via a patch panel (=pure cabling).
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
