connecting the sound of b&o to my television
I have a BeoSound Ouverture typenumber 2636 from B&O with Lab 6000 soundboxes.Just I bought a sony kdl 32w4000 HD television. I want to connect the B&O to my television for using the boxes of my B&O during looking to the television under beolink button PHONO.
The boxes are now connected to the Ouverture with a DIN plug. There isn"t a possibility for using an optical cable because the beosound Ouverture is made or delivered in 2000.
Who could help me with the right advise.
Thankx
bart
Connect the audio output of your TV (usually a pair of RCA connectors) to the AUX input of your Ouverture. For that, you just need a RCA<>DIN cable. Turn on the TV, press AUX on your Beo4, and everything should work! Phono connection is not made for this kind of signal.
thankx for your advice
best regards
bart
