connecting beovision 10 to apple tv
There's also a way of controlling your apple tv direct with the beo4 or any remote you like without the need for a ir blaster. You will have to program it though. I haven't tried this but it seems fairly straight forward. Here's the link
http://support.apple.com/kb/HT3296
That doesn't work, because ATV can't receive the IR codes of Beo 4!
Ok raeuber. Like I said a I haven't tried. Thanks for letting me know. I only knew this because I have read it on hear. Like  I said I haven't personally tried. Have you tried? How about with a beo5?
Thanks again
I notice that the Apple HDMI lead is £15 on the Appe site - Extremely good value.
You can of curse control your Apple TV with either the iPhone or iPad app. Very Very nice app that is incredibly easy to use!
Thanks again
The ATV is able to learn the commands from other remotes than the original Apple remote. But this doesn't work with B&O remotes, neither Beo 4 nor Beo 5/6. But the Beo 5/6 can be programmed with the original Apple TV codes.
So the PUC solution is in my eyes the best and easiest solution to control an ATV with a Beo 4/5/6.
/Räuber
.....which means you should use the IR Blaster
Ok thanks for reply
