Connecting BeoSystem 3 to Samsung tv ?
Hi
I am in the process of moving, and in then 2 months my BV4-50" is stored at my dealers location, until the new place is being finished.
In the meantime i thought it would be cool to connect the BS3 to my girlfriends samsung tv, just to be able to use the PUC controller and my Beo5 :)
I have connected the BS3 to an available HDMI port on the samsung tv using an adaptercable DVI->HDMI. When i switch the Samsung to HDMI3(the connected port) i can see the tv from BS3, i have also connected a Denon DVD player to AV1 with scart cable, and a Playstation 3 to AV2 with HDMI. I have configured the sources in the BS3 correctly, but when i switch the source on BS3 to DVD or V.MEM(the Playstation) the Samsung tv just says "mode not supported" and not picture is shown.
In the configuration on the BS3, i have selected "non B&O screen" as Display 1, and i have set the resolution to the Samsung resolution.
Maybe it is the HDCP that is acting up, and i could understand it with the PS3, but the DVD player is connected via SCART, so that should work.
I have read in the manual to the samsung tv, that when using a HDMI/DVI cable connection, the HDMI2 input should be used, but i am using the DVI/HDMI connection. Has anyone tried connecting a BS3 to an ordinary HDMI port on another tv ?
/Weebyx
I used to have similar problem  with non-Beo TV and it took me some time to sort it out ;-)
cure was following setting in the customer service menu of the BS3 (in <Picture Adjustment>):
Display1
OUTP 60HZ => ON   (default after system reset is Off - in this state no TV-Picture was displayed / only in tuning-menu)
FRAMELOCK => Double Buffer (default is "abort line" -> in this state no AV/HDMI was displayed...)
Only by modifying these settings I could get the whole thing work on my 46" Sony Bravia...
Apologies to hijack your conversation - but I was wondering whether anyone succeeded connecting a Beosystem 3 to a Samsung LED TV, yet?
I do like the Samsung's dimension positvely better than the B&O 4's or the Panasonic's.
Maybe someone reading this can share his or her experience(s)
That did it :)
Thanks alot
/Weebyx
