Connecting Beolab 3's to non B&O equipment
I have an extra pair of Beolab 3s that I plan to connect to a non B&O piece.  I understand I need a line/powerlink adaptor.  What does this look like?  Is it like a Y adapter with two Powerlink on one end and a 1/8" on the other?  And would this just plug into the headphone jack of the amp as that is the only like out that i know of?  Or does it go to the preamps?
I have not bought the amp yet and just need a decent two channel.  Any thoughts would be appreciated.
Regards,
Mo
You are looking for a Powerlink to RCA cable. As the the description implies it consist of a powerlink connection on one end which would go to the back of the BeoLab 3's and the other side would be a male RCA connection, which would be ready for most all preamp/monitor connections. It is not a Y connection so you would need two.  As far as preamp's go I would fine one with controls that fit your prefaces. Stick with higher quality lines and you should be just fine.
Thanks for the reply.  Pardon my ignorance here but there are preamps with volume controls..correct?
Yep - Any good quality pre amp with RCA outputs would be fine!
If you bought a Quad pre amp, you could you use standard DIN cables as they have DIN outputs as standard. They are also really nice!
I think Naim also use DIN, which are also very good...
B&O do a 3.5mm stereo jack to 2 powerlink plugs for using Lab 3 with iPod etc, or single 5 metre phono to powerlink.  Just set speakers to line input and away you go!
Thanks to everyone for your posts.  Very helpful and I'm well on my way.  Thanks again!
