Connecting Apple TV to Beovision 10
Hi all,
I want to connect Apple TV to my Beovision 10. However,i have the model with only 2 HDMI sockets which are already in use and I do not want to constantly unplug . I believe what I need is an HDMI expander. Can anyone recommend one that is compatible with the Beovision 10
Hi & welcome.
The Neet - 3 port auto switch box is well regarded. Cheap too. Great reviews on Amazon.
hi,
This one will work with B&O:
http://www.gefen.com/kvm/dproduct.jsp?prod_id=9151
but you need the PUC added to your system.
hfat
I use the GefenTV, works perfectly with the PUC installed.
Here is the product: http://www.gefen.com/kvm/dproduct.jsp?prod_id=9556
Altona AT-HD4-V41 was the recommended by B&O USA.  There is an PUC code that your dealer will have to install.  Hope that helps.
Why not trade it in for a new one ? I thought the whole point if buying bno was their supposed resale value compared to other brands.
Its probably worth millions by now. You coud probably get a rolls Royce phantom , a Bugatti veyron and half a dozen British banks while you're at it. And get change.
If a bv10 is a tarted up samsung,  and a audi is a tarted up skoda,why does the former hold its value better.
desirability,would you rather have a brand of tv that you can pick up in the supermarket ie samsung in your house,or something a bit exclusive,that you are proud to own,and looks different and unique.,
I would rather drive a audi,even though I know it shares its engines and chassis with the rest of the vw group.Thats brand value for you.B&o know how to do this.To make it desirable(apart from playmaker).
