Connecting an Apple TV to BeoCenter 6-26
I only use the BC6-26 with ATV. I have nothing under AV1 and 2. Your ATV is a set top box no? If you are not planning using PUC you can pick any STB from the list. Did you try?
Haha, yep GEEN is none 😁
Yeeeeeeeees, it’s working. Picture and sound.
Thank you very much Johan for your help (and patience)
riis/
Perfecto! Enjoy it 🤒
Do you have the PUC codes for ATV3 in your STB list or have you used another STB when learning Beo4 the ATV3 commands?
/riis
My BC6-28 did not have the Apple TV puc unfortunately. But I found a workaround: I chose a Humax PUC from the list (as I had a Humax STB lying around) and taught the ATV(4) to listen to the basic Humax commands. It needed some help of the Humax remote, but I got it working.
Good luck!
Johan
I have tried a number of PUC from the list and I can teach the Beo4 the first 4 commands (up, down, left, right), but not the last 2 (Select and Menu).
You are actually 'teaching' the ATV, rather than the Beo4.  Anyway, when I tried this I found that in order for the PUC to transmit sufficiently for the ATV to recognise sound of the commands, I had to press the Beo4 buttons repeatedly (and fast) whilst watching the ATV's 'IR receipt' progress bar move across the screen.  I had to try a number of difference PUCs before I got it to work.
Did you manage to teach the ATV all six commands? Which buttons on the Beo4 did you use for Select and Menu? Do you remember which PUCs on the tv you used?
I copy this - not easy. So I used the remote of a non-used Humax STB to teach the ATV the Humax commands.
