nkbitsch wrote:
Hi everyone!
I'm planning on connecting my active Genelec studio monitors to my BeoCenter 9500. I just can't figure out the best way of connecting them.
The speakers usually runs balanced XLR, though I'm aware that the powerlink doesn't deliver a balanced output. A balanced connection is not important to me.
I have a few XLR -> Jack cables, and as I can figure out, this would be the easiest way of connecting the speakers to the BeoCenter.
The question now is, how would I be able to connect the male jacks to the powerlink output? I found these "Female jack -> 5-pin male DIN adaptors" (linky).
Will they be sufficient, or do i have to build my own cable?
I hope some of you have experience within this matter.
/Niels
You can use your XLR-Jack cables, if the Jacks are mono and the XLR plug is bridged PIN 1-3 (signal-/ground) PIN 2 is signal + and should be on the tip of the jack. Of course you need two of these cables. And yes, you can use the 5pin DIN/ mini jack adapter shown in your conrad-link. PIN3 is left signal, PIN5 is right signal PIN2 is ground (the same is Powerlink out). Now you need a stereo mini-jack to 2x Jack adapter/cable.
Genelecs active monitors with balanced XLR inputs are meant to work usually in a studio environment, which means a +4dbu studio level.
The Beocenter`s Powerlink will output a hifi preamp level, I think which normally means -10dbv. So there might be a little mismatch (not sure, I`m not a technician...), but it should work.
I`d work with 2x XLR/rca plugs for the Genelecs, the 5pin DIN connector for the BC and stereo 3,5mm jack/ 2x rca cable to connect these two worlds.
Or soldering a special cable might also be a good idea.
Nice setup btw...🙂
Stefan
