Thanks MM, this is the setup for the BS9000, I quite like the look of it in this cabinet, the backlights are a recent addition 🙂
Connecting a Beosound9000 to a Beolink Passive amp ?
How about my source is beo essence to a beolink passive to drive beovox 2.2 ? it auto on when recieved a signal but i cannot turn the volume up or down. but i can power it off only . please advice ... thanks
Hi Abeng,
are you sure, that you use the right (fully monted RJ45 to Din) PL cable from the Essence to the Passive amp?
Hi Abeng,
Would you be able to change the volume on the passive with powerlink2 connected or do you change on the connected device?
BR
//Alex
BR
//Alex
You change the volume on the device driving the Passive. The Passive itself has no volume control.
Usually when we talk about the BeoLink Passive, we mean the box (connected to ML) and the connected ir-eye for local control.
However when the box is used just for amplfication, there is no ir-eue connected. Only the (right) PL cable and the (passive) speakers cables (and the power cable).
Since it merely is an amp, all controls are done in the main system (as Stan wrote).
Good point MM. Thanks for clarifying.
Stan
Great, thanks!
