Hi everybody,
I'm trying to connect a Playstation 3 to a BeoCenter 6-26. First try was via a HDMI-to-DVI cable, which gave me a nice 720p picture, but no sound.
So I tried connecting via YPbPr, which this model has existing plugs. But no matter what I do, I only get a black picture with the correct audio.
Can somebody answer me these:
- Any general help to get both video and audio?
- In the connection options, I can connect a Beo4 button (DVD / V.MEM) to both an AV socket (AV1 / 2 / 3) *and at the same time* to either DVI or YPbPr. Does it even matter which AV socket I select?
- Is it correct that the BC6 is unable to play any audio received through the DVI input?
- Is there an option the BC6 to have the picture from the DVI input but the audio from some other input?
- Are there differing versions of the BC6, some with working YPbPr, some without? Where can I find more info about them?
