Is there any possibility to connect a Transceiver/IR-Eye -directly- to a Beomaster 6500? I've got a MCL System with 8 Loudspeakers - in other rooms - installed but my Beomaster - in the main room - is in a cupboard and i would like to use my Master Control Panel while the door of the cupboard is closed?
My White Transceiver has a 6pin-Plug... I can give more informations...How can i connect it?
Thank you for your help!
