Connect my 5 Beolab 3 and a new Beolab 2 to 5.1 Amplifier / Receiver
I plan to connect my existing 5 Beolab 3 to a new Toshiba TV (can't afford a B&O TV).
I have planned the following:
Buy a Nuforce AVP-18 and use it's Pre-outs for the Beolabs. I think I will need this specific trigger cable to switch on the Beolab 2. Other than this - will this work? Do I need the trigger cable for Beolab 3 too? They are currently hooked to a Bose Lifestyle system - works more or less but I have some speaker humming and hissing sometimes and some clicking when input signal changes Stereo to 5.1 and back etc.
I assume and hope that with clean Pre-out signal i won't an issue with humming and hissing.
The Nuforce is my choice because of limited room in my rack and my better half won't allow a Yamaha or Denon monster on the sideboard.
Thanks for help.
You will need a trigger cable to avoid the speakers turning off in low volume situations.
See here: http://archivedforum2.beoworld.org/forums/p/2420/20863.aspx#20863
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I am using the BL3 as the rear surrounds via the RCA plug to PL without a trigger cable.  I have not noticed any problems with those speakers shutting off at inopportune moments.
D
