Connect door intercom to Beoline ISDN
Hello,
I wonder if it is possible to connect a door intercom to a Beoline ISDN. I thought about using a converter box that is able to act like a DECT phone but offering a standard analogue port which can be used for the intercom interface.
Does anyone know if it is possible to connect such a converter box to a Beoline ISDN (the older version able to support up to 6 devices).
I could use a separate telephone system where the Beoline could be a child-device parallel to the analogue door intercom. But I read that the BeoCom 2 has a different ring tone for internal calls (or is this an incorrect information?) which I would use to differentiate between external calls and door intercom calls.
Thanks in advance for any helpful advice.
I saw a demonstration from SIEDLE, which works with all bang olufsen phone's and TV`s
http://www.siedle.dk/App/WebObjects/XSeMIPS.woa/cms/page/locale.enFI/pid.221.223.324.2443.1957/Siedle-cooperation-with-Bang-Olufsen.html
I think you should contact your local service provider . I am using the voip phone systems  for my residence and voip has many advantages .
