Yes, still works fine
Connect beovox 4500 to beolab 4500
Thanks for the reply. How’d you physically connect them, special hardware? How’d you mount them, special brackets? Have you experienced any overheating from the amp? How did you put them in series? I have so many questions because I would like to do something similar.
sorry to bother you again but how did you connect these? how did you connect the wiring at the back?
- The Beovox 4500 is connected in parallel to the Neolab 4500 speakers (on the output of the Neolab 450o amp)
- No special hardware used to mount; I used the standard wall-mount and mounted the Beolab 4500 and Beovox 4500 speaker individually (each speaker on its own wall-mount). works fine if you measure carefully.
Regards, Bieele
