Anybody experience in the above?
Condensation inside the LCD panel of BV7-40
Yes.
It is most likely the seal between the chassis and glass. There were some that were faulty - or deteriorated prematurely. Contact you local dealer, if under warranty it's a quick fix. Other wise it's not an expensive job.
with the greatest respect, I probably would have a qualified technician sort this - than risk fracturing the glass prying it in any way.
I am in 100% agreement with Dude1 on this, this gear is toooo expensive to be prying.
