Cleaning Beovision avant screen
hello everyone
Does anyone having trouble to clean Beovision screen from handprint?
I also have same problem.
My dealer say "Do not use widow cleaner" because coating will came off.
What is the best way to clean the screen of TV.
tnks for kind answer andrew
I always find that some dishwashing liquid with COLD water is the best
Don't use warm water it won't stop streaking.
Then dry with a soft cloth
Hi
The best product we have found that works well on all TV screens is Fast Glass by Auto Glym. Spray a small amount on screen or microfibre eco cloth and wipe gently away and it takes seconds without leaving any streaks
thank you michael
just ordered soft cloth from internet
thank you
I ordered this one from Internet cost me usd 20
I will try with soft cloth
thank you
