Chromecast no longer an option on Harmony 77 (Solved)
Hi all,
I noticed a couple of days ago that for some reason, my Harmony 77 no longer seems to be available on Chromecast like the rest of my B&O speakers/TV’s. It appears in Spotify, but without the Chromecast option and isn’t available in Google Home at all.
Does anyone know if this is a known issue or if there’s a way to rectify?
Thanks,
Ben
Works fine on mine
Is that on a Harmony 77?
Should not matter - 77 is the size of the LG screen/tv.
The options of Sound Center is the same for all sizes.
I have the same issue. Chromacast audio on the soundcentre (Harmony 77) is now gone since the spotify update.
Dion.
Thanks Dion. Good to hear it’s not just me, hopefully it will be sorted soon. I spent 2 hours last night trying every trick in the book to get it working to no avail. Fingers crossed for a speedy update as it’s an integral part of my set up!
I think its important for everyone who's having this issue to report it to B&O. Both to your dealer and within the App. As probably the number of people having a 77" Harmony is not that huge so when there are no complaints nothing will happen.
Anyone here with a smaller than 77” Harmony, who has the same issue?
yep; i have the same problem with the Harmony 65“; customer support informed, no respondiere yet
Wolfgang
I called customer service last night. Unfortunately it cut off whilst I was on hold, but I did receive a follow up email basically saying to contact my dealer, so I’ll do that tomorrow and report back.
