So basically, it works like Beolink Multiroom without the need for the Beomusic app?? And as long as the speakers have Google Cast?
I did not know this!!!
No, not quite - you can't just 'join-in' like with BeoLink Multiroom.
You will have to adress a single speaker or one or the grouped speakers, that you have configured with the Google Home app.
One of the adventages over AirPlay is that the device itself fetches the stream - the 'sending device' is just a controller, the initiator.
With AirPlay the 'sending device' is permanently engaged and thus occupied with streaming..
On the other hand you/iOS users can airplay litteraly anything. You can only cast from cast enabled apps!
