Hi!
I'm looking for a blu-ray player to go with my new Beovision 10. I want something really good that can decode internally and output PCM(for HD-sound). What players are out there? I have looked around a bit but I feel confused. One mayor issue I noticed when playing blu-rays with the PS3 were the really slow start-up times. Are blu-ray players usually this slow?
An other important thing is the integration with the BV10. How does it really work, and what brand works best with B&O? Controlling my blu-ray with a Beo4 is really important and I want it to work as smooth as possible.
What players do you use? What do you recommend?
Felix
