Changing harddisk at Beosound 3200
Hello,I have some questions concerning changing the original harddisk from my Beosound 3200.1. Can i replace this original harddisk to a ssd sata which will be connected at a ide 40 pins to sata converter and yes;2. will there be enough space left to build this converter and ssd into my BS3200?3. Is opening the BS3200 an easy operation?4. Is there any document that shows/explain me how I can open the BS3200 to get acces to the harddisk?I know I probably also have to clone the original IDE harddisk to the SSD drive.I normaly use the Macrium software solution. I hope it is also suitable for the this action. Hopefully this software will recognize the original BS3200 harddisk.I am very pleased and thankful with all your tips, information. If you have any questions about my plan, please do not hesitate to ask.I thank you all for your kind help.🙏
