changing Beovision 5 grille/fret
Dear friends,
After successfully remove the aluminium frame of my BV 5 I'm not able to remove the cloth grill. I have tried to unscrew the silver bolts around the grille but the panel rejects to be removed, any ideas will be welcome.
I remember doing this for a customer once the the frame has been removed you remove all the screws surrounding the fret ( there are a few) it should be a case of simply grabbing the top of the fret and you should be able to take it out from there
