Hi all,
What center speaker should be preferred for a 5.1 setup with
BL17 (Rear)
BL18 (Front)
BL19 (Sub)
The idea is to use the above speakers wireless with transmitter 1 and an Marantz AV7704.
Centre could be both wired and wireless.
BR Micke
Hi all,
BL17 (Rear)
BL18 (Front)
BL19 (Sub)
BR Micke
BeoLab 10 / BeoLab 7-6
Beolab 10 is not an option unfortunately due to the design is not approved by my partner.
I've found an Beolab 7.4 for 290€.
What is the difference between a Beolab 7.4 and 7.6?
Any other options?
BR
Micke
That is the exact setup I have using a Marantz AV receiver, only difference is that I use bL 15 built into the ceiling as rear speakers, and
I use a Definitive technology center speaker which has a built in sub woofer as well and it works marvelously
Good luck
Thanks, I ordered the 7.4.
Now I have the problem to find a good media cabinet/furniture. 😕🙂
Today I have a white cabinet 200/42/35cm (length/width/height) hanging 15cm from the floor.
Would like a similar setup with 2x media cabinets with approx 80/40/35cm measure and have the BL 7.4 in the middle.
Have not found any good media cabinets to use or adapt yet.
Hallo Mavven
Hallo Mavven
link
Many thanks! 🙂
What tv do you have? I made a bracket for an old BV7 stand, works perfectly 😀
A samsung 75 inch tv. My idea is to have it like this, see illustration attached.
So far I cannot find find any cabinets that I can hang on the wall that are
length: 80-90cm
Height: ~35cm
Depth: min 45 cm (inside).
I like the style of Clic. 🙂
