Hi Terry:
That is truly wonderful news! My pleasure as it is always rewarding to see our beautiful B&O up, running and doing what it is designed to do. And especially great if one doesn't have to spend money to achieve that end.
Yes, the TM73 was the most difficult for me after my Mk III laser change as it required a few runs for it to "take". On my Mk II, it took on the first run.
In reading your original post, I concluded early on that if the Test Mode adjustments were to solve the problem, that it would be the TM 73 and not the TM 71 that was at the root of the problem.
Now, If I can only make some progress on my "in-need-of-repair" B&O! I have two BeoMaster 6500's with blown output stages, a BeoSound 4000 in need of a door belt, four BeoLab Penta I's that require complete restorations and a BeoCord 6500 in need of belts. I'll get to them slowly but surely (I just built a Dim-Bulb Tester to help with the BM 6500 troubleshooting) and will enjoy every minute of it!
The best to you Terry!
Sincerely,
Michael
Lowell, Massachusetts, USA
