CD player fault on my Beocenter 8500
Dear every people on Beoworld.๐Ÿ™‚
My cd player fult on my BC8500. The cd mekanise its at CDM 4/57 the cd start very fast at after short it stop at open the top gate again. I think lazer itis okay, because there are a red ligyte into in, but the motor spin ekstreemly fast, can one of you maybe help me?
With kindly regards
Henrik
Denmark
I'm not an electronic tech boy but I had the same similar issue. On the old forum (where pictures are dissapeared!!!) I saw that one specific elco (capacitor 2103) on the CD boards has to be replaced. So I did, and guess what?๐Ÿ™‚
hey Keith thank you for the tip, but dont work that I repalce 2103 capitor, so  I thnik what can be wrong?
Wow, got a new name, Keith๐Ÿ˜
Anyone else? Now I'm stucked helping Henrik...
It has to be a specific 2130 capacitor, I suggest you contact member Dillen
okay du you mean i shall try to replace 2130 capacitor?
It's actually C2103 and can be read about HERE
I'm hoping that link works, I haven't tried linking to the old forum before.
I have try to replace the 2103 with a 33uf capitor, bur dint stil work  ๐Ÿ™Someone here they have repair this problem befor on BC8500/9500 before, and can the problem only be on the servo print or can the decoder print give that problem about too fast motor?
As long as the replacement C2103 was the blue Philips axial type, exactly as the original and not another manufacturer then I can't advise further. Hopefully Dillen or Joeyboygolf can suggest the way forward.
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
