Hello guys new to the forum
I have a Beosound 9000 which has been sitting there for the past 2 years and decided to start using it again. However I found that I put the CD in a slot, I could select the player to move to and mount. When I press play the CD will only move about 5 to 6mm and the display would only read the CD Number and 00:00.
After looking through the internet I found that it is a common problem that the lasers fail so I have now replaced it but it is still exactly the same.
Any ideas about what else I could try?
