My grandchildren visited & now my BS3 is not responding to the Beo4 signals. I'd appreciate some pointers from our knowledgeable members in this forum.
i have tried disconnecting the power to the BS3 to try to reset it but to no avail. I'm in western Vanada & the only service tech the local dealer relies on is very busy & it usually takes quite a while before I get to talk to him.
specifically I hope I can get some ideas on how to find information on diagnosing the beo4 and the BS3.to locate the problem, which can be the beo4 inadvertently got re-programmed by my grandchildren, or the BS3 got stuck somehow because it didn't shut down properly. I checked the Beo4 & it is transmitting signals.Signals but the IR sensor doesn't blink or do anything except for the red standby light on continuously. Can someone tell me whether the bs3 has any standby light indicating it's on & also whether the power cord is polarized (the cord that came from the dealer does not have the Square-round ends which would only allow the cord to be connected one way?
