Can't play my music from the sc card
Hello,
Can you help me?? I finally received my BeoSound 4 and BeoLab 4000, its brilliant!! love it...cant get enough of it.
However, I copied some music from CD to my pc then onto the SC Card, but when I put the card in my BeoSound, I can see it runs through the albums and songs I have put on there, but does not play them. Any idea why?
 Thank you in advance if you can help me. Oh..I use Windows Media Player
Chris
Probably the file structure. If you have a Windows computer, I would load Beoplayer and use that. Bound to work then. It doesn't mean you cannot use WMP but it will show you which file structure to use. The only other issue to think about is the compression you used and the file type. Small extract from manual!
