Ralf wrote:
i have tried the BeoPlay App now on some Android machines. I can assure, that it works on none of them.
The M5 was always found but when you try to connect the 'WIFI error' was thrown.
On Android >= 6 the app sometimes crashes.
Very, very disappointing, Bang & Olufsen.
(I love my old ML network, quick response and never failed)
The new beta Bang & Olufsen app works much better (however, does not find ML/NL gateway :-) ), but you cannot change M5 sound settings yet.
You have to switch to iOS, i can confirm that this works with M5.
My dealer told me, that sound setting will be added soon in one of the next updates.
Ralf
I bought an M5 as an early birthday present for our daughter, and I have been trying to get it to work with Android also. Conclusion: its a total failure... After a loooong wait you get finally your Bluetooth phone connected to the M5, next you notice that using the Androids BeoPlay app for a setup is not working.
Luckily I have an iPad in the home and the M5s setup process has been working as a charm on this tablet. The first setup, playing individually and in Multiroom with the iOS Beomusic app has giving me no problem at all. What a relieve!
Some other problems... The M5 is not able to connect with the Androids Beomusic app?
I list it:
- Not usable on the Android Beomusic app
- Working on the new Android app, but this is still in Beta form and not fully usable.
- Setup is not fluid working as should on the Android Beoplay app.
- In using the new Android app, this app is disturbing other Multiroom products in your home (your favorite TuneIn list... on other Multiroom products)
- In the latest software update they removed the possibility to pair it with a wheelie remote.
What kind of a new product launch is this for the latest new speaker at B&O? Or needed they something new to present at the CES fare, even although it is not completely finished.
