Can't connect M5 to Beoplay App - can anyone help?
I went through a whole ordeal with B&O on the phone getting my new M5 connected to my wifi network (ended up using BeoSetup....which is mentioned nowhere in the manual).
I can now using Google Cast, etc., but I can't get the M5 added to my devices in the Beoplay app. I'd like to be able to adjust the equalizer and room adjustment settings.
Can anyone help? The error message I get says: "Products doesn't seem to be available on this WiFi. Connect the phone to the same WiFi as the products..."
Of course, I am connect to the same network - I only have one wifi network.
I'm very frustrated. :/
M5 not able to be connected to the Beoplay app only the BeoMusic/set up apps. Using beomusic under product settings you can adjust bass & treble though. Hope that helps.
Dave
I don't understand - the instruction manual specifically says to use the Beoplay App - plus I can't locate any EQ settings in the Beomusic app (am I missing something?)
It's a Beoplay products - why wouldn't you be able to use the Beoplay app?
have you been in the bluetoothsettings of your device and connected the speaker manually?
Dave
sorry, you are wrong. at least with my M5.
I have connected the speaker with both Bluetooth and Ethernet. No success with the Beoplay app. :(
I have go to the finalisation process in the BeoPlay app but it just hangs. I have successfully setup two units via BeoSetup app. There sound adjustments for Bass, Treble and Loudness should feature in a new software update. I currently find the M5 to overpowering with the Bass.
I also find the bass over powering....I'd really like to be able to adjust it.
The tonal control feature is coming soon. 😕
Wouldn't be useful to me if I can't connect to the app! :(
