Can't connect Beo4 to AppleTV
I have:
AV2: VMEM
PUC: AV2
STB: Apple Remote
HDMI: A
Autoselection: YES
 I unpaired the Remote of the apple tv.
Still doesn't work???
What am I doing wrong....
ps. dreambox 500 no problem... ( i even switched IR cables to check if this one was broke)
Beo serviceman was here again - this time also the iPod Remote software was installed, but still it is not possible to control the AppleTV with Beo4. Those of you that succeded must have done something very special. Could there be differences in BV7-40 Mark III in US versus Europe that could explain these problems?
/M
More food for thought on this topic....
Last night I brought home a new AppleTV and connected it to an Avant/US which has the 4.7 software installed, and the 4.7j CCDB.  Attached to the STB input, everything works, everything.  I did not have to 'unpair' the remote. I just had to struggle for a few minutes getting the correct resolution output from the AppleTV.
If it's this easy on an Avant, there ought to be no problems on BS-3 based systems.
Russ
It works on my BV8 including fast scroll and forward/backward. Some of the sources are not linked to an IR control port.
I have mine under TV, HDMI Yes, STB Ipod Remote. It worked under DTV as well. I believe it can even work with a paired remote as long as you pair it with the IR plug that is attached to the cable. I think most ATVs ship with an unpaired remote ayway.
Cheers
JK
