cannot store tv stand position (MX7000)
Hello,
 I have an early version of the mx7000 on a motorized stand. I use a Beo4 to control it, the problem however is that I cannot seem to store the startup viewing angle of the stand. What I do is that I use the STAND button to rotate the stand, then I try to store the position by pressing VSETUP/STORE, and the channel indicator on the TV turns red. I switch off the TV and when I then turn it on again, it goes to the old startup position, not the one I chose.
Anyone have an idea of what to do?
 Many thanks!
 Filip
Hi
On my MX7000, it works as follows:  With TV on, press MENU, SETUP, STAND.  Message then says "turn stand to preferred position".  Use left / right arrows to get correct position and GO to store it.  EXIT and switch off.  When you switch back on, stand will go to the preferred position.
Regards
Geoff
Hi Geoff
The problem is I have the first generation of MX7000, where the menu is more limited. I don't have a STAND menu item under setup. Thanks though!
 /Filip
I think you need a Beolink 1000 to do what you want!
You have to press STORE twice, while the STAND settings are still displayed on the screen.
It stores all the pictures setting at once (like Brightness, contrast, etc..).
p.
Works! Thanks p.! Owe u one.
/Filip
