Guy wrote:
So a related question if I may (probably for Chris): If you select 'TuneIn' on the Essence using the Beo4, can you then change station/programme using the number buttons?
Yes, you can with the Beo4. Activate radio on the Beo4 and change a station by pushing a number or use the up down button. Station numbering is related to the order you give them on your TuneIn user website.
You only need an Beoremote One to activate a Link source, this won't work with the Beo4. You can off course use also the Beomusic app for activating a Link source.
To put everything again in a row:
a) A daily operation of only the Essence sources (without Link sources) works perfectly with the Beo4 + IR-eye.
B) Daily operation of Essence sources (with any Link sources) works perfectly with the Beo4 + IR-eye + Beomusic app.
C) If you want to use the Essence sources AND any Link sources from the comfort of a remote, you need the Beoremote One + IR-eye.
Millemissen wrote:
One possible solution would be to use the MyButtons/BROne for 1 or more of the stations in the TuneIn list.
You can add any source (sources from the Essence or sources from Link products) to the four MyButtons. Also the possibility to add Matrix sources (Atlona?) but NOT a specific radiostation who is behind a number on your remote.
