In my complete ignorance I thought that as the red wire didn't go anywhere it was there to confuse the B&O system that it was B&O that was present -- from what you are saying, Peter, this is a one side of the stereo only arrangement.
This is rather annoying to say the least. The 8000's have RCA compatibility and fire up on a signal (according to the manual) is this likely to happen with non B&O sub-woofers. A Non- B&O subwoofer should be the easiest to put in the system because of the abundance of active equipment.
In an RCA arrangement you would expect two pins and not one and the sub-woofers would have two sockets to take left and right. Do you think this was drawn this way to illustrate the wiring of one of the pins with the red and (another)ground going to the other pin?
