Can i stream to a NL/ML converter from the X app?
Tried as you suggested. I selected the ML/NL that is attached to the BV7 in the X app. I went to music and tried to select a song from the DLNA server. I receive the error message "could not insert into playqueue". I then tried radio instead. Same issue, but a different error message: "action not supported by the selected product".
To clarify - I am using the beta version that is public as stable in the IOS store. I am not part of the testlfight betas. Has this bug been fixed in the meantime?
No,it's still an issue.
I am using the TestFlight beta.
Looks like what I am experiencing is a RESUME function. i.e. I can restart on the BLC the last Deezer "collection" I was playing on the Essence.
I repeated my test, and if you recall I had let the ColdPlay selection run to its end.
This time it started back at the begging of the ColdPlay selection.
I then tried to switch the BLC's selection and Plex DLNA insertions and Deezer insertions all failed.
Even the one I had resumed would not insert [:\'(] see image below.
However I was able to insert by activating the Essence (and setting its volume to 0) but that's hardly a realistic use case.
Got it. So, it is confirmed that the testflight beta is not at the feature set of the beomusic app yet when it comes to ML/NL support. Let alone adding more functionality.
Fingers crossed that this is being worked on and fixed soon.
