Can i blutooth my beocenter 9000
Hi guys
Does anyone know of a bluetooth adapter i can plug into my 9000, so i can play songs or spotify from my smartphone
Many thanks
Merlarky
After trying many bluetooth adapters/receivers, I really like the Audioengine B1.
http://audioengineusa.com/Store/B1-Bluetooth-Music-Receiver
and used it extensively with my Beocenter 9000 via a 5pin din to RCA from Steve at Sounds Heavenly.
http://soundsheavenly.com/bang-olufsen/52--2rca-5pd-.html
Hi Peter
Just realised i cant spell....many thanks for the links
That looks a nice bit of kit...cheapest ive found so far is £139....
Ive bought leads from Steve before, he is a very nice and helpful guy.
Its not my main stereo set up, but i have it running through a pair of beolab penta mk3
They are just suberb, so like to make the most of it.
Cheers
Gary
£139, if google exchange rate is accurate, sounds about right. They don't really seem to show up used for sale often or on sale.
I think the quality DAC in the B1 is a nice feature for using digital on a system like this. I was convinced at first that music from my iPhone sounded better and fuller via this receiver than just hard wired into the aux without an external DAC on the Beocenter 9000.
My setup varied with the BC9000, I ran it with RL 140s, CX100s/cona, M70s, and Beoplay S8. Would love to try it with some pentas someday, though.
Hi Peter...
Just an update..i managed to get hold of a audioengine b1...what a nice bit of kit...
Now subscribed to Spotify so i can make use of the highest 320 kps bit rate for downloads...sounds great.
Thanks for the recomendation.
Cheers
Gary
😁 Great!
I looked at these options - but went the route of a cheap ( Tesco Hudl2) android tablet for the job, running spotify and digital radio feeds via the Aux.  Sounds great, easy to use, well under £100uk all in.
Hi
I much prefer Google Audio Chromecast to bluetooth - they say the sound is better (I can't tell - ears getting old) but it's more stable than bluetooth.
Cheers
Nigel
And they're only £20 from Currys / PC World at the moment!  You will also need an adaptor to convert the mini jack plug into a DIN plug like this one
http://www.ebay.co.uk/itm/Android-iPhone-MP3-3-5mm-Jack-to-Naim-Quad-B-O-Lead-5-pin-din-1m-WHITE-Cable-/252281935018?hash=item3abd2cd4aa:g:tVIAAOSwG-1Wuf5M
Cheers
Nigel
Keep in mind that most times you will need the paid services to be able to use Chromecast Audio - but at that price, I'd get one anyway.
I'm a freeloader, so for the little Spotify use I have, I usually AirPlay to the Chromecast that is connected to my TV and from there to the Beosystem 😁
