Hi guys
Does anyone know of a bluetooth adapter i can plug into my 9000, so i can play songs or spotify from my smartphone
Many thanks
Merlarky
Hi guys
Many thanks
Merlarky
Hi Peter
Just realised i cant spell....many thanks for the links
That looks a nice bit of kit...cheapest ive found so far is £139....
Ive bought leads from Steve before, he is a very nice and helpful guy.
Its not my main stereo set up, but i have it running through a pair of beolab penta mk3
They are just suberb, so like to make the most of it.
Cheers
Gary
Hi Peter...
Just an update..i managed to get hold of a audioengine b1...what a nice bit of kit...
Now subscribed to Spotify so i can make use of the highest 320 kps bit rate for downloads...sounds great.
Thanks for the recomendation.
Cheers
Gary
I looked at these options - but went the route of a cheap ( Tesco Hudl2) android tablet for the job, running spotify and digital radio feeds via the Aux. Sounds great, easy to use, well under £100uk all in.
Hi
I much prefer Google Audio Chromecast to bluetooth - they say the sound is better (I can't tell - ears getting old) but it's more stable than bluetooth.
Cheers
Nigel
And they're only £20 from Currys / PC World at the moment! You will also need an adaptor to convert the mini jack plug into a DIN plug like this one
Cheers
Nigel
Keep in mind that most times you will need the paid services to be able to use Chromecast Audio - but at that price, I'd get one anyway.
I'm a freeloader, so for the little Spotify use I have, I usually AirPlay to the Chromecast that is connected to my TV and from there to the Beosystem 😁
