gordonlyons1 wrote:
I believe you are correct Martin, I also now suspect a faulty IR sensor as I have tried every other possible recommendation by members, problem now is, where can I get a sensor? I have already the net to no avail :(
Gordon
I've had a look at the service manual and the IR receiver PCB feeds pretty much directly into the microcontroller (via a single resistor), so unless there is a broken track on the main board, I'm definitely inclined to suspect the receiver PCB, or the cable connecting it to the main board.
I've just checked, and the receiver module is (as I suspected) no longer available from B&O as a spare part. It is however pretty simple so ought to be fairly straightforward to repair at a component level if a replacement cannot be obtained elsewhere.
How comfortable are you with opening up the BeoCenter? From memory, the IR receiver PCB is pretty easy to access, but I would upgrade your beoworld membership to at least silver membership and download the service manual if you intend to go down this route.
I'm happy to take a look at it for you given you're quite near to me, but I've very busy over the next 4-6 weeks so it would need to wait a while.
Martin.
