Can anyone help pleeeease. Beo4 remote not working with Beocentre 9300 grrrrrrrrrr
Hi
I need to know how to get my beo4 remote to work with my beocentre 9300, I have had 1 reply so far on a different thread but it didn't work, need more help please.
Thank you very much
Gordon
Hi try setting the BC 9300 to Option 1
Make sure that the BC 9300 is in standby befor you begin.
Press and hold LIST & STANDBY till you see ADD? flasing in the display, then tap list till you see Option then press GO now tap LIST till you see A. OPT. then point the remote to the BC 9300 and press Number "1" key the BC 9300 will blink one the from the sandby led if done right.
If it blinks from the led it should turn on when you press RADIO if not try the option setup again
/ Bjørn Andersen
Hi. Sorry to read you are having remote control problems. I'm guessing the first suggestion from anyone would be to make sure the 9300 is set for audio signals, ie, audio option1. I'm sure you have already tried this but may be worth trying again anyway.
Are you sure the Beo4 is ok? Have you changed the batteries? Sorry to state the obvious but it's worth asking. Do you have any opportunity to try another Beo4, or try yours on another system? Is the 9300 working ok on the touch panels?
I have my 9300 set to a.opt 1 so it only responds to audio signals, I feel this is the underlying problem here but can't quite pinpoint how to get round it yet. I'll have a look back through this forum to see if anyone has had a similar issue. (I'm sure you have already).
Graeme.
Hi Bjorn thank you for your reply.
I have tried this from a member in a previous thread but it does not work. When I press `List and Standby` on my Beo4 the first thing I see is `Config`? and not `Add` also it does not flash. To get option for A. Opt  I need to press `List` until `Option` appears then press `Go` then `List` until I get `A. Opt`, then I press 1, but nothing happens. I know the remote works because it worked fine with my Ouverture, I`m stuck and unsure what next. Can you help further???
Many thanks
Gordon
Hi Graeme
Remote works fine as I was using it with my Ouverture just a few days ago, only just got my 9300. Panels work fine on the 9300, can you helppppp???
Gordon
Where do you live? I can probably lend you a Beolink 1000 so you can get the 9300 working.
Brixham South Devon Peter
Are you totally sure that the BC9300 was at standby (i.e switched off) before starting the procedure?
I live just outside Plymouth. I also have a spare BL1000 also you can borrow. Did you press 'go' after getting a-opt in the Beo4 list before pressing1?
PM me if you are interested in the Beolink 1000 but if your  Beo4 was ok previously it should work fine with the 9300. I have 3 Beo4 and the BL 1000, they all work with the 9300.
As I said PM me if interested but obviously I won't give my email out here as I will be hit with spammers for sure!
G.
Many thanks
Gordon
The remote you have can it controlle other devises than the Overture? like a TV?
also if you tapping the list do you see a "LINK" while tapping the list? if so try LINK -> GO -> RADIO and see if its turns on
