cable setup for cona subwoofer?
I am buying a cona subwoofer-I've seen the wiring diagram on this website but it is still unclear to me-
How do I connect cables to it? Are they 2 din plugs or 3.5mm, or just bare wire?
and if they are wire only, what grade of wire is recomended? where to purchase it in the UK?
thankyou so much, guys
Hi shuni,
             the connections are very simple. There are Left & Right cable inputs (from your amp) & left & Right outputs to your speakers. All connections are screw clamp onto bare wire.
Chris.
They are just bare wire. The connectors are of the screw type.
I have one of these and just thought to add that you'll need two DIN plugs to connect to your Beomaster from the input side, and two DIN socket plugs to connect up to your B&O speakers from the Cona's output (hope this makes sense).
thankyou so much for your replies, now i know what to do. cheers
