cabinet question
You should have seen it before the cabinet, i'm waiting to get my hand on some mesh wire tidy so hopefully in the next week it'll be looking a lot neater.
Speakers?? B&O off course (or are you pulling my leg). BL9's at the front and BL7-1 for centre and i have BL3's for rear.
It works a treat, with the one exception of being able to turn it on/off with the Beo4. We have the IR controller on the screen but it doesn't want to play ball. I think i might be going with the BV4-50 in the new year, in an attempt to complete the system, also to get rid of the ghastly glass stand i'm stuck with....
LOL of course i'm puuling your leg ;) i even know the weight and specs on each and every Beolab in the current range *sad i know*
I'm Jealous! You must get the B&o panel ;)
Hey, until then.... replace the GHASTLY glass stand with a huge long block of wood, or a simple low line cabinet...? It'll help keep things neat and nice?
You beat me too it with the sad comment, but hey, i'm sure they'll come in handy one day.
What i want to do is locate the cabinet on the other side of the room. However i'm stuck finding a cable tidy that will carry the hdmi for the screen, three powerlinks for centre and two fronts and ALSO the sensor cable for my Wii....think the sensor bar cable won't be long enough.
It does house the 7-1 nicely though, a perfect fit if you ask me. I think i'll hold out on a new cabinet. I'll get the BV4-50 and a floor stand, similar to the BV7 range so won't need a cabinet.....off course i'll have to upgrade the 7-1 to 7-2, much to my dealers delight.
