cabinet for beovision 7-40
Hi
Weird one.  I have got a beovision 7-40 and i would like to have it in a cabinet that hides the tv completely and then when switched on it will actually come up through the top of the cabinet.
Does anybody have any idea of what company would manufacture such a product?
Please help
Sound like you actually wanted this SONY. Hiding the BV7? 😁
Interlübke Cube system does this very well. I'm not sure if it works with the BV 7-40, but it's well worth checking out.
The Cube is exactly what I am looking for.
But they dont have anything for a beovision 7-40
Thanks for the help though.
try ikea link
or copy of 7-40 stand!!!
link
Try here. I have bought from this company in the past. They make some pretty neat stuff.
Simon.
Hi there,
This company used to make one, but does not appear to be in their current brochure.  You could try contacting them to see if they could help as they supply to retailers and may know of a store which has one.  They make very high quality furniture, and from memory the TV cabinet was about £4500.00 (ouch) !!!!  The cabinet was was exactly what you wanted.  They are located in SANDY, Bedfordshire and WROXHAM, Norfolk.
After much searching, I'm going to have one custom fabricated for a client for deliver at the end of this summer. At least in the US, where B&O has a smaller presence, there is no option to accommodate the set.
I can suggest you a plasma-lcd TV panel from mdfitalia, see
