Bvis 7-40 MK2 And MacMini
Hi Guys
Does anyone know of any problems, using the new macmini with Bvis7-40 Mk2, the TV has been upgraded with the new hd panel and the latest software. Customer already has a skyhd box fitted and is using the DVI socket, as far as I know I cant use the componet connection, as there is no connector available. The new 2009 macmini are digital only, can I still use the vga socket??
Regards
Kai
What gives you the impression that the actual Mac Mini is "digital only"?
Take a look at Apple's specification:
  • NVIDIA GeForce 9400M graphics processor with 128MB or 256MB of DDR3 SDRAM shared with main memory3
  • Extended desktop and video mirroring: Simultaneously supports up to 1920 by 1200 pixels on a DVI or VGA display; up to 2560 by 1600 pixels on a dual-link DVI display using Mini DisplayPort to Dual-Link DVI Adapter (sold separately)
  • Mini-DVI port
  • DVI output using Mini-DVI to DVI Adapter (included)
  • VGA output using Mini-DVI to VGA Adapter (sold separately)
  • Mini DisplayPort output
msinn
