BV9+Playstation3+Beo5 = works perfect
Is PS3 on the STB-controllerlist in the TV ?
Or how do you control the PS3 with the beo4.Is it play, stop, rewind when playing Blue ray?
Trucker
Anders,
can you move through your music, pictures, etc... or does it only work with the movie menu?
Because I am not a gamer I have had no interest in the PS3. However now I am looking for a blu-ray player that has flexible outputs so that I can continue to use scart connection to my non-HD BV6-26. This would enable me to upgrade my DVD1 without forcing me to change the TV now.
This is even better if you can control the darned thing with a beo4. Because I don't know this product at all can anyone explain the on/off switch thingy. You all, obviously, understand what is going on but I don't. Is the devise being talked about from schwartz an infra red on-off? which will work with an stb?
Sorry for my ignorance but I have never owned a gaming machine.
not for that price
schmartz cost 30 dollar and 50 with on/off function
The problem with waiting for the HD TV before you get the HD player is that you have to buy both at the same time. Getting one at a time enables you to get what you want which may be constrained with a double purchase.
Does the one remote allow the same sort of access as the stb? In other words will it allow link room access? If I wanted the PS 3 and bought the one remote when its available in March would I need anything else or will that do the job?
The one remote is more expensive but if it does the job then it looks tidier and the PS 3 does have a BL 4000 look to it.
