BV8 Switching to an audio source
If my BV8 40 is turned on to Video source like TV (DTV since the analogue tuner is turned off in the settings) and I press a audio sorce like Radio then the display is not turn off. Of course the picture disappears but you can see that the display is turned on but is black. Is the an error that the display is not turned off?
It BV8 is turned off and I press Radio then the music plays and the display i not turned on. Wired.
I have the newest software version.
My BV8 40 is in option 2 and my BS3000 is in option 0 (no speakers).
Is there a reason for this behavior or is at a software error?
When switching to an audio source, my BV8-40 turns off the display after about 30 seconds.
BV8-40 with speakers connected via masterlink with BS4.
The sceen of my BV8-40 turns off (black sceen), if I switch from TV to the masterlink connected BS4. But turns on again (after 30 sec. off) if I`ve to make a modification in the DSS-modul of the telly.
