BV7 + Wii component = stand runs wild
Hi guys.
I need help! Or suggestions..
I've conncted a Wii via component to my BV7 MkIII. After this my stand position is acting VERY strange. It's become autonomous.. Example: When I turn off the TV it'll go to the utmost right position. Turn it back on and it'll go to the full left position. Turn the DVD on - it might go slightly left.. if you get the picture.. If I try to (via the standard menu option) reposition the stand it will respond - but as soon as I exit the menu it goes "scr_w you - I'll go to what ever position I please.." Same goes if I adjust via the remote..
Can anybody help?
Best regards
Sundby
Hi there - I had the same problem. This bug was fixed in firmware 4 and greater. It was a feature of 3.5. I would put up with the bug for a few more weeks while B&O's QA procedures for software improve as 4.24 actually has more bugs that surface everyday. Although I would say that picture quality is better than 3.5.
 Bugs that I am experiencing in 4.24
- When Sky HD box is connected to BV7 with HDMI and Scart (for the masterlink capabilities) then seeing SKY on remote Beovisions intermittently fails (whilst sound continues).
 - All Beovisions in a Link system can fail to startup/respond from the Beo4 or Beo5.
 There is of course of seperate thread to the 4.24 issues that are worth following to find out when 4.3 become available.
 Best, Mark.
Add this discussion to the thread:
http://forum.beoworld.org/forums/thread/130955.aspx
