BV7, Wii and component cable
Please could someone help me I have tried to connect my wii to my BV7 using a component cable, I have tried everything i can think off after 3 days have managed to get sound but no picture does anyone have an answer. many thanks
I had the exact same problem and finally got it to work. It's kind of tricky since the BV7 can't display 50 or 60Hz settings via component cable.
You need to connect your BV7 via SCART cable first, so that you get a picture and and can navigate through the Wii Setup menu. In the Wii menu you will find the section "TV type". You will see the that the "EDTV/HDTV (480p)" button cannot be selected since you are using a SCART connection. Now it becomes very tricky, since you need to select that button and confirm it without being able to see it.
I put my Wii controller on a coffee table and used a couple of books so that the controller would point exactly on the "EDTV/..." button. I also checked the position that the controller would need to be in, in order to select the "Confirm" button. After having the controller in the correct position, i disconnected the SCART and replaced it with the component cable. Sound should still be there, but no picture. Now select (blindly) the "EDTV/..." button and then the confirm button. You should here the sound from clicking the buttons and shortly after you should get a picture. It might take a couple of attempts, but it will work!
Another solution would be to connect your Wii to another non-B&O flat screen TV via component cable and change the setting there. Most flat screen TVs will not have a problem to display the 50 or 60Hz settings via component cable.
I hope this helps.
Good luck!
Dennis
What you could try is take the green component lead and plug it into a yellow rgb slot (for example camera slot on BV7).
You get a black and white picture but you are able to make the adjustments.
(have not tried it, but on other websites, they use this as a workaround)
Matt.
