BV7 Software version
Hi all
I have a mk2 bv7 that I need to find the software version of... I know how to go into service menu but from there I am lost... can anybody point me in the right direction...
thanks
Hi
Press menu, go to Options and press Red + Go. In the next menu, you can see SW option. Press Go and the SW Version will appear.
Thanks for the reply.. under the service menu I get ap sw: 7.0 & a few other fields.
Am i looking at the correct field?
Anyone.. is ap sw the correct field for the version of software my bv 7 is running?
Last version for your TV is AP SW 7.7; M2 SW 7.74; TV SW 7.84
Regards
Thanks quim
What is the current software version for BV 7-40 MK3, please?
5.08a
Thank you. I was confused as there are so many version number in the user config menu, service menu, etc.
