BV7 settings
I connected an Apple TV to my BV7 mk3 at the weekend. Eventually up and running, however I think I might have upset the setting for connecting my Sky HD box.  At the back it is connected via HDMI & Scart. What settings are correct for connection, what is the best STB profile. AFAIK it is a Thomson SKY HD box. I just feel that the picture is not quite as good as it was before I started fiddling with the setup.
Are you sure that the setup for your sky box is using HDMI and not scart?
Piet
At the moment I have set it to HDMI. To be honest I do not know why the scart connection is there, but that is the way it was installed.
The Dealer from whom I purchased the BV7-40 went out of business in December last year, so I am a bit high and dry in terms of support.
you dont need scart unless you have link rooms that are getting the sound/video from the HD box
i have mine only set up with HDMI and SPDIf as SKY dont allow Dolby over HDMI
