Ok.... :-)
I've a BV7 Mk2 (no hdmi) and a link BV6
Connected to the BV7 is an early Sky HD box - It's connect via component for the HD and Scart for the sound and signal to the BV6. The picture is great on the BV7 and very acceptable on the link BV6.
The MacMini is connected to the BV7 via DVI to DVI for the picture. I have a display port to hdmi cable, that is then connected into a hdmi to scart converter and from that to the BV7. The audio is coming from the phono on the mac mini into the same scart plug from the converter. The picture on the BV7 is great, but on the link is fairly terrible.
As a test I connected an old laptop with s-video out into the camera connector on the BV7 and the picture was the same terrible quality as i'm getting from the scart converter.
Any thoughts gladly accepted. All the other inputs to the link tv are great, Sky, DTV ( the bv7 has a digital tuner fitted ) and the DVD.
:-D
