Douglas wrote:
Hi, the component socket is analogue therefore you got some sort of image, how did you connect the ps3 ?
Good point D.C, I bought a Component cable for the PS3 from Maplin's as the only option I had for HDTV in the BV7's Menu was YPbPr. It was connected from the PS3's Multi-AV socket, which is usually just a composite connection.
Douglas wrote:
Best thing is to phone your dealer and ask about the upgrade, they should be able to tell you straight away on the phone!
Why dont you ask a dealer about an exchange deal for a MII or MIII BV7-40
D.C
I was planning to call them today but as I was made redundant 6 weeks ago, we have put a hold on all non-essential purchases, I wonder how I can get this one under the radar 👍
Thanks again D.C
